obd1 check engine light
Old Apr 10, 2015 | 08:49 AM
lgoodgrace's Avatar
Default obd1 check engine light
Need help figuring out how to check for code on car obd1 and ecu has no light
Old Apr 10, 2015 | 04:41 PM
DAdemon93's Avatar
Default Re: obd1 check engine light
The ECU will not have a light on it, you have to refer to the yellow check engine light on the dash. On the passenger side of the vehicle, located in the same vicinity as the ecu is a wire with a plug on the end. You use a paper or wire to connect the two terminals of the that plug, which will cause the check engine light to blink in sequences of short and fast flashes. record the sequence in which it flashes, this is how you indicate what codes are being thrown. There's plenty of forums and tutorials that cover this topic.
Old Apr 12, 2015 | 01:08 PM
mattmaine1991's Avatar
The wire on the passenger side will be blue use a paper clip or what I use is a wire. Once That's in turn the key.
Old Apr 27, 2015 | 03:43 PM
lgoodgrace's Avatar
Yea well after a little research i figured it out
My chip was loose which was causing check random check engine light (code) jerking and cutting off after taking it out and plugging it back in ive had no more problems
hunter fitch
Engine Management and Tuning
Feb 1, 2019 11:12 AM
jdmsir4dr
Apr 4, 2010 12:04 AM
hothondas
Aug 4, 2008 06:24 PM
OMGBBQTEHWTFDOOD
Oct 19, 2007 10:18 AM
