no fuel from pump
Old Apr 26, 2015 | 01:44 PM
pappasmurf's Avatar
Icon2 no fuel from pump
I have a 94 accord lx that reently refused to start, it will turn over but not crank. I have replaced the distributor, the main relay, and the fuel pump; as well as straight wired the fuel pump from the battery. now i am getting no fuel from the pump all the way back at the high pressure fitting coming from the pump to the metal fuel line. I really need some help as this is my only transportation.
Old Apr 26, 2015 | 03:27 PM
holmesnmanny's Avatar
Default Re: no fuel from pump
It sounds simply like your fuel pump is dead.
Old Apr 26, 2015 | 03:42 PM
pappasmurf's Avatar
Post Re: no fuel from pump
just replaced fuel pump. tested before installation
Old Apr 26, 2015 | 03:48 PM
David_ek4's Avatar
fuel pump fuse? how is it? in good condition?
Old Apr 26, 2015 | 04:27 PM
pappasmurf's Avatar
Only fuel pump fuse on car is main relay. bought a brand new one and replaced it already.
Old Apr 26, 2015 | 10:02 PM
Have you tried priming the fuel pump, then opening up the fuel filter to rail fuel hose 17mm bolt just to see if your fuel pressure tester gauge is bad ?
Old Apr 27, 2015 | 12:12 AM
pappasmurf's Avatar
not very experienced here in fuel systems how do you prime the fuel pump? please let me know, it is something i have never had to do before.
Old Apr 27, 2015 | 08:20 PM
prime just means turn it on by applying power and ground but then turn it off .. it'll still have residual pressure, if you leave it on it will keep spraying .. then check if fuel sprays out when you open the bolt
it's possible you think you're powering it up but you're not .. you really should just put it back to stock and check for fuel pressure after turning the ignition on and off
Old Apr 29, 2015 | 09:36 PM
SpokaneSpeed's Avatar
Just a heads up, if it turns over that means it cranks.. no start no crank means nothing turns over.. just an FYI ;-)
Old Nov 11, 2024 | 07:43 AM
D16y8vitara's Avatar
Check the fuse box. My 95 civic blew the #24 fuse and it melted in the fuse box. Idk what it goes to but that's what kept my car from starting. I went and bought new interior fuse box and swapped old one out and put a fuse connector in place of the fuse so it doesn't melt in the fuse block again
NovaRex
Dec 4, 2015 05:10 PM
4doorcivic9
Jun 11, 2008 06:31 AM
Cameron60
Jan 16, 2007 06:04 PM
Dee A Nine
Aug 24, 2004 02:45 PM
Z6REX-SI
10
Mar 9, 2004 07:50 AM
