H2B header vs. H-series header
I'm finishing my build and only need a few small things. One being an exhaust manifold. I found a good deal on a decent h2b header, but not sure on the difference in angle for the lower portion of the manifold. I'm running an H22 with H22 trans and Hasport mounts in a 92 civic chassis. The manifold has a flex pipe on it. Will this be usable or does the h2b header angle too much to clear the subframe? Thanks for any info.
Brandon
Brandon
If I remember right it was a 7* difference between a factory h22 header and a h2b spec header. If a flex pipe will make up that difference I'm not sure.
eg:R
May 29, 2009 01:49 AM
