how do you test a p28 ecu? no start
Old Apr 5, 2015 | 07:00 PM
nyckid's Avatar
Default how do you test a p28 ecu? no start
is there a way to test a ecu to see if its good or not? trying to trouble shoot my no start
Old Apr 6, 2015 | 03:33 AM
7rrivera7's Avatar
Default Re: how do you test a p28 ecu?
If you don't have en engine SIM, try your ECU in a friends car or your friends ECU car. For this to work, MAP sensor and Injector CC's must be the same across both cars...
Old Apr 6, 2015 | 08:20 AM
nyckid's Avatar
they dont own hondas
Old Apr 6, 2015 | 06:56 PM
VegasInvasion's Avatar
I'm Huge In Japan
there is no way to bench an ECU without an engine simulator. you can open up the case to see if anything is obviously burnt or poorly installed, but that's it. send it to someone for testing, or get another ECU from a JY.
Old Apr 6, 2015 | 07:07 PM
nyckid's Avatar
ecu looks fine/nothing burnt
new batt
new icm
new cap
new rotor
new main relay
new coil
plugs and cables are good
all fuses are good fuel pump primes and sprays out when i loosened the nut from the fuel filter
distributor gets power
grounds are good
Old Apr 7, 2015 | 06:29 AM
nyckid's Avatar
ttt
WideBodyFEELZ
Engine Management and Tuning
Sep 24, 2020 07:45 AM
I CRX I
Jul 30, 2010 09:15 PM
trunkluv
17
May 30, 2010 08:02 AM
hybridb18
Apr 9, 2004 04:09 AM
