turbo question
Old May 6, 2015 | 07:06 PM
mattmaine1991's Avatar
Default turbo question
I have a 96 civic hatch. It will not start but when I crank it my boost gauge jumps and sounds like it's spitting air out.
Do you think I have a vacuum leak?
Old May 7, 2015 | 05:47 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: turbo question
Do you know how to check for boost leak? Vacuum leaks are not usually causes for a no start problem. Go through regular steps to diagnose. You need compression, fuel, spark, air.
Old May 7, 2015 | 10:03 AM
Not to sure about boost leaks. It has spark and compression is good. When I tried starting it to sounded like a little splash of air and the boost gauge jumped.
Old May 8, 2015 | 05:44 AM
Vtak_GoKart's Avatar
Is it getting fuel then? if it was getting everything (Fuel, Air, Ignition) it would at least attempt to start.
91crxturbo
Jan 8, 2007 04:48 PM
bard329
Feb 22, 2006 07:02 AM
akad3mikz
May 4, 2005 02:58 AM
Sinner
May 24, 2004 10:44 PM
