fuel problem/ecu?
Old Mar 29, 2015 | 08:32 PM
Honda1956's Avatar
Icon2 fuel problem/ecu?
I just put a new motor in my car and i try to start it and it turns over but it wont start. i checked to see if the fuel pump was running and it wasnt. Why isnt it running? the pump is getting power. its got a good ground. the pump was perfectly fine before hand. I did noticed that when i turn the key to on position. the check engine light doesnt come on. the battery light and oil light comes on thats it. I didnt hear the main relay make any noise so i changed it and its still doing the same thing. I checked all the wires, grounds connectors and still can't figure it out. I did put different injectors in, RC 440 sats. but i doubt its that but any help would be great thanks.
Old Mar 30, 2015 | 06:53 AM
SpeedRacerEX-R's Avatar
Default Re: fuel problem/ecu?
Did you blow a fuse anywhere?
Old Mar 30, 2015 | 01:36 PM
2point1's Avatar
Sounds like your ecu isn't getting power or ground. Check fuses to see if you have a blown fuse. Make sure all plugs are plugged in.make sure the thermostat ground is hooked up.
Old Mar 30, 2015 | 01:45 PM
Honda1956's Avatar
I checked all the fuses
Old Mar 30, 2015 | 02:07 PM
94dxcoupe's Avatar
check your engine grounds. Most often forgotten is the ground from valve cover to the radiator support and the ground on the thermostat housing.
Old Mar 30, 2015 | 06:48 PM
holmesnmanny's Avatar
You checked both the engine bay fuse box assembly and the dash fuse box assembly ?
It's possible your ecu crapped out.
radicaled434
10
Apr 27, 2012 04:10 PM
175Shot4Door
Apr 20, 2010 05:42 PM
stkinge
Nov 21, 2009 08:38 AM
Dead CIVIC
Jan 27, 2009 04:35 PM
92awd4u
Sep 27, 2004 09:23 PM
