99 Civic Sedan Automatic - Jacking Issue
Old Apr 8, 2015 | 06:07 AM
ashtonallen's Avatar
Default 99 Civic Sedan Automatic - Jacking Issue
When I jacked up the front of the car, I noticed the jack must be pulling the car forward several inches. I got a little confused because when you use the front jack point, the car tilts so the drivers side is a bit higher. Once I got the car high enough to put stand under the passenger's side, I put that stand in place. I then put the driver's side stand where it "should" have been once the car was lowered enough for it to settle on that jack stand. Once the car was low enough, I noticed the driver's jack stand wasn't in the correct position. Further, once I got everything in place, I went to look at the wheel chocks in the back. They were a few inches from the tire. I have to assume the car moved forward as it was being jacked up. Should this happen?
Please let me say that I know jacking up a car isn't rocket science, but it's really hard to find clear and consistent answers on the correct procedure. I have a few questions:
When do you engage the parking brake when jacking up the vehicle
When jacking up the back, should the car simply be in park
When jacking up the front, should the car simply be in park
Thanks for bearing with me on this!!
dclub01
Aug 18, 2003 04:21 AM
B18cteg
Jun 8, 2003 06:22 PM
Krakhor9
47
Oct 19, 2002 06:32 PM
type r 01-1063
May 7, 2002 07:18 PM
4dGSR at work
Mar 28, 2002 11:29 AM
