Cam Gear Whining
My stock cam gears whine like there is no tomorrow. Any ideas on what this could be? It sounds like a bearing is shot, but there are no bearings that I am aware of.
Tom
Tom
ummm........easy way to replace it.........bassically you gotta remove the crank pulley and the upper and lower timing belt covers...........then from the wheel well you will see the tensioner. take out the 14mm bolt and remove the tensioner. make sure you dont loose the spring.
another 15min of work you could have the belt off too.........might as well change it........
DOH!
Just had a friend swap a new motor in the car and throw a new timing belt on (300 miles ago). So i dont need to change it, just loosen it up some.
Tom
Tom
Loosen the tensioner bolt 180 degrees and then manually rotate the engine over 5-10 times to get the timing belt to tighten up, once you remove any excess play tighten the tensioner up and you're on you way. Shouldn't take more than 5 minutes max. HTH
Ben
Ben
hondaeg8
11
Oct 4, 2004 08:49 AM
