is it difficult to change out the distributor??
Old Oct 25, 2001 | 04:47 PM
b18bvudoo's Avatar
New User
Default is it difficult to change out the distributor??
do you just pop it in and set the timing? i have a helms but i havent been able to find it since i moved, so i thought i'd put this question out. tia
Old Oct 25, 2001 | 04:53 PM
madslackin's Avatar
Default Re: is it difficult to change out the distributor?? (vudoo666)
Yep, that's it.
On the end of the intake cam, there is a slot for the distributor to slide into. This only goes in one way, so if you have a problem getting it to mount properly, turn the distributor 180 degrees and try it again.
That is a horrible explanation, but you'll figure it out.
Justin
skhell
Jan 16, 2018 11:37 AM
Northernlightz
Jan 4, 2016 07:22 PM
taguchi09
Jun 11, 2011 04:52 PM
Atomic1
Mar 17, 2010 06:17 PM
fire7882
Jun 24, 2002 05:37 AM
