B20VTEC machining
i am getting ready to drop off all my parts fer my B20VTEC monster on monday... what all machining do i have to do to the block>> im not too clear about it but for some reason i think that theres something that has to be drilled or the dowels enlarged or something....?? i know about the pistons clearance(valves) etcetc.. i just need DETAILS>.. as far as mating the head to the block...
rite i figured that out now....BUT i need DETAILS... i found an old import tuner article i was looking for.. it says to enlarge the dowel pins on the head to move them so they fit but WHICH n WHERE>. which dowel pins do i use and where do i move them.. where can i find out more about it.. i knoe its the same as an LS/VTEC buildup... i KNOE that CRVTEC.COM and B20_net.com doesnt have any specifics on it.. i need DETAILS...thanks
You could try running a search over on the boards at http://www.theoldone.com
Just don't post anything, or you'll probably get bitched at. They're pretty touchy over there.
You need details? Check this link. It shows an LSVTEC conversion, but the b20vtec will be the same.
http://www.c-speedracing.com/howto/lsvtec/lsvtec.html
