oem sway bar questions
Old Oct 21, 2001 | 09:15 PM
DreamSpeed's Avatar
Default oem sway bar questions
which is the best front and rear sway bars from honda? Is it the Type R? I have a 92 civic cx and i was wondering what i need to install a Integra Type R front and rear sway bar in my car? thanks
Old Oct 21, 2001 | 10:57 PM
rainforest's Avatar
Default Re: oem sway bar questions (DreamSpeed)
yeah the 22mm type r rear sway is the best you can get, as for the front iam really not sure. you will need gsr lower control arms mounting brackest for the sway bar and some other stuff look it up on hybrid honda arcived articles.
Old Oct 22, 2001 | 10:01 AM
BSQ's Avatar
BSQ
For complete step-by-step instructions (w/photos and part numbers) for installing the Type-R rear swaybar (22mm), go to my website at http://www.geocities.com/bretq/swaybar_install.html
I have seen the GS-R/Type-R front swaybar (24mm) installed on a '92-'95 Civic before, I will post the link if I find it.
Old Oct 22, 2001 | 11:19 AM
DreamSpeed's Avatar
Default Re: oem sway bar questions (BSQ)
thanks
Old Oct 23, 2001 | 02:46 PM
Ive's Avatar
Ive
Thanks for providing the link. I tried to download the PDF file you have on there but it said it has exceded bandwidth limits. Do you have it hosted somewhere else where I could get it? Or is it small enough to email?
Thank you kindly in advance.
Ive
Old Oct 24, 2001 | 06:58 AM
BSQ's Avatar
BSQ
Default Re: oem sway bar questions (Ive)
Sorry about the problem trying to download the PDF file. Geocities has been giving this message periodically for the last couple of weeks. It appears that they have implemented something that limits the number of hits to a website. Therefore, if a lot of people are accessing my website, this message may be displayed. The only suggestion that I have is to just retry periodically.
I did email the Type-R rear swaybar installation instructions in PDF format to you.
Old Oct 24, 2001 | 10:56 AM
Ive's Avatar
Ive
I didn't receive it in my email, but I tried downloading it again today and it worked just fine.
I Just want to thank you again for that. Very well done write-up!
-Ive
Old Oct 24, 2001 | 11:32 AM
Katman's Avatar
..you own a 92 CX eh?
well you can use any front LCA (lower control arm for short) from any 92-95 Si hatchback or EX coupe or 94+ Integra (any model).
As far as the front swaybar goes, if you want the biggest OEM front bar, the GSR/ITR bar is the biggest to fit your EG - which is a 24mm bar. Yes both ITR and GSR are the same exact bar & endlinks. The next size up is the Si coupe's front swaybar which is 26mm, but I believe that will not fit on a 92-5 civic or 94+ integra at all.
If you do get a GSR/ITR front swaybar, make sure you get the endlinks, rubber d-bracket & bushings.
here's a diagram that will help you out..
....as far as the rear swaybar goes, you can either go Brett's route or....the way I did it was a little different. If you check out Honda-Hybrid's ITR rear swaybar install, you'll see my write up on it. I bought a Prothane D-bracket kit and used that along with the 94+ integra OEM rear mount plates and the rest of the mounting hardware from a stock 94+ integra rear swaybar ON the ITR rear swaybar...
http://hybrid.honda-perf.org/tech/ITRon5G.html
Old Oct 25, 2001 | 12:06 AM
DreamSpeed's Avatar
Default Re: oem sway bar questions (Katman)
awesome! thanks man after all this posting on multiple boards this is the best answer yet thanks!
hey katman, do you have an aim screen name i'd like to chat with you sometime, you know your pretty famous around these parts (i live in alhambra) anywho sorry to hear about your b17a hybrid (i know it's old news but) anyways hit me up if you have the time my aim screen name is Imported8317 thanks
[Modified by DreamSpeed, 1:09 AM 10/25/2001]
Old Oct 25, 2001 | 12:21 AM
DreamSpeed's Avatar
hey, so basically if i go to the junk yard and find a 94-01 integra GSR and just grab the lca the sway bar and all the hardware it should just bolt right in right?
Old Oct 25, 2001 | 08:31 AM
Katman's Avatar
..that's right.
I do have an AIM name, but I don't give it out. I already have too many people hit'n me up in the middle of work. You can always email me though
Old Oct 25, 2001 | 09:54 AM
DreamSpeed's Avatar
cool, no problem
Old Oct 26, 2001 | 11:03 AM
Ive's Avatar
Ive
Default Re: slightly off topic.... (Katman)
..that's right.
Sorry to be off topic, but I've tried emailing you Katman about having some ECU chipping done and I don't know which email you are going by or checking. Can you please let me know which one you use so I can forward you what I wrote/asked about?
Thank you kindly in advance and great info about the sway bar mod.
-Ive
ive@axion.net
mynameizstitch
Jul 20, 2009 09:39 PM
ekinshuya
May 31, 2009 07:36 AM
jpb105079
Oct 31, 2005 01:48 PM
921.5CXEG
Jun 23, 2003 08:09 PM
DreamSpeed
Oct 26, 2001 11:30 AM
