need help with field sfc-vtec wiring !
Old Oct 25, 2001 | 03:28 PM
safe driver's Avatar
Default need help with field sfc-vtec wiring !
help! i'm trying to install the field vtec controlling on a 96 ex civic. the unit was used so there isn't any manuals. the instructions on "http://asia.vtec.net/beystock/field/sfc-vtec/" are a joke. it doesn't even tell you to connect the ground wire, plus it doesn't have anything for ecu's newer than 95. i need to know which wires from the fields unit to connect to the ecu. here is what i got from the http://asia.vtec.net/beystock/field/sfc-vtec/ site so far: red - power, green - rpm, blue - vtec signal, light blue - speed sensor, brown - sensor line. i would like to know if these are the correct wires to hook up and if there are more wires that needs to be hooked up.. ie, the vtm wire.
DVS Luder
Oct 11, 2007 03:47 AM
lsvtec90
Jun 15, 2005 11:37 PM
blueskiesfade609
Apr 16, 2004 10:32 AM
CTRwannaB
Dec 6, 2003 04:52 PM
