serious stalling issues HELP!!!
Old Oct 28, 2001 | 09:02 AM
John's Avatar
New User
Default serious stalling issues HELP!!!
unfortunately, my hesitations and stalling issues were not rectified when i replaced my distributer (*sigh*)... and last night, my car hesitated violently several times, and at a stop light, my car stuttered, the oil light came on, then the CEL came on and the motor cut out... after 5 attempts, i finally got the motor to turn on again... i've had issues with the CEL in the past, but the oil light coming on really worries me... i'm trying to get the codes for the CEL light, but it's kinda difficult when the CEL goes away after each time i restart... HELP!!!
Old Oct 28, 2001 | 09:59 AM
rainforest's Avatar
Default Re: serious stalling issues HELP!!! (DunReit)
so what code are you getting.
Old Oct 28, 2001 | 10:29 AM
John's Avatar
New User
Default Re: serious stalling issues HELP!!! (rainforest)
well, that's the problem... i can't get the CEL code since i have to restart the car (so that i can get myself back home)... and unfortunately, the CEL goes away when i restart it...
where exactly is the wire harness that i need to tap into to jump the CEL to get the code? i know it's behind the center console somewhere, but does anyone know exactly where it is?
Old Oct 28, 2001 | 10:46 AM
OneThirtyEight's Avatar
...im a retard, i thaught u were talking about an integra. Sorry.
[Modified by 97blackteg, 2:47 PM 10/28/2001]
Old Oct 28, 2001 | 01:48 PM
flymecourageously's Avatar
New User
i think you need to look at the obvious first being the battery/,maybe needs charge or replaced. have it tested.to check for codes behind the kick panel there is a service connector which you jump and then you read your cel blips to get the code there was a real informative website concerning that topic.but i would check the charging system starting with the batterry
Old Oct 28, 2001 | 06:51 PM
John's Avatar
New User
Default Re: serious stalling issues HELP!!! (flymecourageously)
http://www.eastcoastdelsol.com/columns/view.php?id=9
that's the site i believe you may be referring to...
if i was having problems with battery, wouldn't i have problem starting the car and such? also, wouldn't my stereo be acting up? i really doubt that there's a problem with that or the alternator, but i'll check anyways...
so does anyone know where the wire harness is for the CEL so that i can jump the circuit? (i have a 95 accord ex-r)...
Old Oct 29, 2001 | 07:53 PM
John's Avatar
New User
after doing some thinking... i began to consider that the ground for the ECU might be at fault... maybe it's loose or something... where on the car does the ECU ground for a 5G Accord?
Dead CIVIC
Jul 28, 2009 07:17 PM
music462
Apr 10, 2008 05:37 AM
mafia
Jun 25, 2007 08:22 AM
flatline
May 20, 2003 10:58 PM
