Energy suspension instruction sheet
Old Apr 12, 2003 | 02:56 PM
vegan_punk's Avatar
Default Energy suspension instruction sheet
I got my es master set #16-18103 for my civic hb. I am missing the instruction sheet #17140 for the rear end control are bushing set. If anyone has it can they email me a scaned picture of it or does anyone know where i can get one online?
Old Apr 12, 2003 | 06:16 PM
vegan_punk's Avatar
Default Re: Energy suspension instruction sheet (vegan_punk)
anyone?
Old Apr 14, 2003 | 09:06 AM
vegan_punk's Avatar
someone help me
Old Apr 14, 2003 | 10:25 AM
X0's Avatar
X0
I have it somewhere, but i'm at work right now. I'll find it tonight. I should have it scanned and posted tomorrow sometime.
Old Apr 16, 2003 | 01:10 PM
vegan_punk's Avatar
Default Re: Energy suspension instruction sheet (BAdMutHA)
find them?
Old Apr 19, 2003 | 04:06 PM
vegan_punk's Avatar
anyone?
Old Apr 19, 2003 | 07:33 PM
NonovUrbizniz's Avatar
Loved
92-95? if so I have them but at home (i'm at my rent's house in NY).
I'll be back 2moro I'll take pics (sorry no scanner) if this dude doesn't.
Old Apr 20, 2003 | 10:22 AM
boosted3g's Avatar
Default Re: Energy suspension instruction sheet (NonovUrbizniz)
dude they are super easy. Jsut take a torch and burn the rubber out. CArefully cut the remaining ring out. And then grease up the bushing and push them in. There is only 2 bushing (3 if you do that shock mounts) and they are the same. Its supe easy, instructions are just troubleshooting manuals. Try it and see if you can do it without the instructions.
Old Apr 20, 2003 | 06:46 PM
vegan_punk's Avatar
Default Re: Energy suspension instruction sheet (boosted3g)
I don;t know the part #'s and there are more than 2 in the rear. The trailing arm and stuff. Does the upper arm that connects the trailing arm to the body with 2 14mm bolts get changed?... Instructions would be nice.
Old Apr 22, 2003 | 03:15 PM
Loved
hey man sorry... I'm missing that one too.. I had it before but... i have good news... the main sheet they gave you (the parts list) has the bushing and pin numbers grouped together above the instruction page number. So if you have the main page it should tell you which bushings you use there. just no instructions but like was said... it's pretty straight forward.
good luck If I find my inventory page or that instruction sheet I'll give you the info.
Old Apr 22, 2003 | 03:24 PM
Loved
ALSO.. you should be able to get ES to fax you the instruction sheet you need as well as the proper bushing numbers.. I had to have them fax me the instructions for my motor mounts because it came with none.
GoOD LUCk Again
Old Apr 30, 2003 | 02:02 PM
X0's Avatar
X0
Whooo-hoooo found 'em! Buried under the piles o' crap in my garage. I know it's probably too late for you Vegan Punk, but someone may still need 'em.
These are the instructions for the energy suspension master bushing set, for a 96-00 civic (ek) w/ manual tranny, part #16-18110.
PAGE 1
PAGE 2
PAGE 3
PAGE 4
kelviiv
Suspension & Brakes
32
Oct 10, 2010 09:20 AM
dsmarefaster
Dec 28, 2005 06:59 AM
erebunicrx
10
Mar 12, 2005 06:45 PM
drdavidge
May 9, 2003 11:54 AM
