DC SI VS ITR 4-1 Header
Old Apr 14, 2003 | 06:26 AM
jdm4life's Avatar
Default DC SI VS ITR 4-1 Header
Does anyone know if there is any difference between the two? Size of tubes?
Old Apr 14, 2003 | 08:59 AM
Padawan's Avatar
Darth ModerVader
Default Re: DC SI VS ITR 4-1 Header (jdm4life)
The collector flange will have a different angle because of the different cats. used, and the Si version is most likely shorter (height, not length) than the ITR because of the B16's shorter deck height. I would imagine tubing diameter is the same on all of DC's VTEC headers (JDM 4-1 and USDM 4-1 are the same), although I am not certain of this.
Old Apr 14, 2003 | 09:02 AM
BerlinaAP2's Avatar
Default Re: DC SI VS ITR 4-1 Header (Padawan)
the tubing diameter on the jdm header has a 2.5" collector, and the usdm one has like a 2. 25" or something
Old Apr 14, 2003 | 09:05 AM
jdm4life's Avatar
So it should bolt up to my JDM B20B fine?
Old Apr 14, 2003 | 11:34 AM
Padawan's Avatar
Darth ModerVader
The Si version may not be tall enough to clear the oil pan.
Old Apr 15, 2003 | 05:06 AM
jdm4life's Avatar
Really Can anyone else let me know if that is true or not
Old Apr 15, 2003 | 11:29 AM
Padawan's Avatar
Darth ModerVader
Either way, I would run something with a larger collector on a 2.0 L motor.
Old Apr 15, 2003 | 12:07 PM
MPower332TI's Avatar
I would recommend the jdm 4-1. Fits perfect on the b20b and youll love it.
Old Apr 15, 2003 | 12:29 PM
BerlinaAP2's Avatar
Default Re: DC SI VS ITR 4-1 Header (jDmDxTuRd)
i wanna get the DC jdm 4-1, i heard it hangs LOW tho, but it will fit on a b16 w/ some cat work
.M.
Jul 28, 2004 07:32 AM
99silverbullet
May 19, 2003 08:20 PM
typeR 507
Jan 5, 2003 02:12 AM
hybrider
Feb 23, 2002 01:12 PM
HX_Guy
Aug 31, 2001 10:01 AM
