building a b18a
Old Apr 10, 2003 | 08:09 PM
driftergts's Avatar
Default building a b18a
Im getting ready too rebuild my B18, I would like too get some advice on what brands of stuff I should buy. Im going too need the basics too rebuild a bottom end. So if any one has any ideas on the things I should pick up I would be very thankful
Old Apr 10, 2003 | 08:23 PM
lazy bum shaughn's Avatar
Default Re: building a b18a (driftergts)
What kind of application are you running, all motor or forced induction?
If you have money just send your block to get it resleeved to an 84mm bore with JE pistons and Crower rods.
Old Apr 11, 2003 | 05:02 PM
driftergts's Avatar
Default Re: building a b18a (lazy bum shaughn)
im going too run N/A for the most part, but hope too add a 2 stage set up on it later. This is sorta a budget build and was wondering what bearings, rings and seals were the best too use. Thanks
Old Apr 11, 2003 | 05:13 PM
Well dude man, think of a plan first, and stick with it(unless you're sure you want to change). If you want turbo(I'm assuming that stage 2 is turbo?) then by the internals now for the block preperation.
Old Apr 11, 2003 | 08:14 PM
driftergts's Avatar
stage 2 set up is going too be nitrous. I was hoping too get some advice on the best brands of bearings, piston rings, seals and ect. thanks
Old Apr 11, 2003 | 08:15 PM
riceboy's Avatar
if your going with a budget build, then dont even build a motor, it will be cheaper just to buy a B18A from a junkyard for five bills and go with that.
EDIT - but as for bearings, OEM honda, and rings, use the same brand of ring that you do piston. budget all motor build? Use b16 pistons.
Old Apr 12, 2003 | 12:04 PM
driftergts's Avatar
Default Re: building a b18a (riceboy)
The thing with the motor is that i got a 90 integra ls for 30 bucks. The only thing is that the motor needs a crank. I got the crank, and was wondering what was the best stuff too put in it. Thanks
ChrisCoupe1
Sep 15, 2015 09:07 PM
B00stedEh3
Aug 5, 2007 08:04 PM
Tad
10
Oct 11, 2004 05:16 PM
ptsaurus
Mar 20, 2004 05:33 PM
user 996328629
Nov 14, 2003 08:50 AM
