s1 compared to ys1????
Old Apr 11, 2003 | 09:08 PM
4inspeed's Avatar
Default s1 compared to ys1????
whats the difrence in gears gime somethin to work with i want a new tranny and was wonderin wich to go with, its a b16 crx btw.
Old Apr 11, 2003 | 09:35 PM
TREVER's Avatar
Default Re: s1 compared to ys1???? (4inspeed)
I just did my first ys1 it's much better than a y1. It's a type r tranny in a different case. the synchro design is better.
Old Apr 12, 2003 | 06:24 PM
4inspeed's Avatar
Default Re: s1 compared to ys1???? (TREVER)
ok but what are the gear difrences compared to a s1? wich would be better for a stock b16?
Old Apr 12, 2003 | 08:18 PM
Quick 200k Mile Motor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER &raquo;</TD></TR><TR><TD CLASS="quote">I just did my first ys1 it's much better than a y1. It's a type r tranny in a different case. the synchro design is better.</TD></TR></TABLE>
actually, the JDM S1 has exactly the same gearing as a type r (excluding the type r w/ 4.7 final).
Compared to the JDM S1, the JDM YS1 has a shorter 1st and 5th.
Old Apr 13, 2003 | 11:04 PM
4inspeed's Avatar
Default Re: s1 compared to ys1???? (Quick 200k Mile Motor)
ok so would the usdm ys1 be good for a b16?
Old Apr 14, 2003 | 01:53 AM
4inspeed's Avatar
cmon guys i need help on this, wich would be better for a b16? the jdm s1 or the usdm ys1??? i need to know sson cause i can get a great del on the ys1 but i dont want to miss it.
Old Apr 14, 2003 | 07:50 AM
ricodemus's Avatar
You will always be faster with the shorter geared transmission, which is the ys1. If you already have the s1 though, you won't notice much of a difference since they are very close in gear ratio's, with the ys1 being a little tighter (like someone said earlier). I personally wouldn't go through the trouble if I already had an s1 in good shape in the car. How much are you getting the ys1 for? ****, I would buy it for a back up if it was that cheap. May be you can sell it to me (I only have a y1 ).
Old Apr 14, 2003 | 05:56 PM
4inspeed's Avatar
Default Re: s1 compared to ys1???? (ricodemus)
ok i thought the ys1(ls tranny) had taller gears, but i guess im wrong(good for me) i want a new tranny anyway, i have slight scratches every once in a while. so i can pick up this tranny *cheap* and im a mechanic so instalation in the shop is really easy, so its just about wich one is better to me. thanks guys i'll be gettin the tranny tomorow, o ya and sorry but im keepin it. sell you a s1 with lite grind tho
Old Apr 14, 2003 | 06:52 PM
ricodemus's Avatar
Ok, what s1/ys1 are you talking about? I was assiuming you were talking about the jdm s1 and the ys1 found in the 92-93 gsr, but there were other ones. Check this chart out. It all depends which one you are talking about. Sorry for the confusion, I just assumed.
http://www.allmotorhonda.com/t...s.htm
Old Apr 14, 2003 | 06:58 PM
jdmDXrex's Avatar
the USDM ys1 can come on the 92-93 GSR's but they also put that same "ys1" name on some of the USDM LS trannies too. just like Y80 and S80 for the USDM 94+ integra trannys....(GSR and LS) sometimes the only way you can tell the difference is if you pull the tranny apart or you drive it..... anyways just wanted to help clear things up.
Old Apr 14, 2003 | 10:17 PM
4inspeed's Avatar
Default Re: s1 compared to ys1???? (jdmDXrex)
ok sorry for bein so stupid but the smaller ratio means the gear is taller right or is it the other way around? the smaller ratio, the smaller gear??
Old Apr 15, 2003 | 04:58 AM
sleeper4dr's Avatar
look at it this way... here are the specs from the 92-92 GSR YS1 tranny
3.307 1st
2.105 2nd
1.458 3rd
1.107 4th
0.880 5th
4.400 FD
see what is happening? think of those numbers and then think of each gear while you are driving. the LOWER the gear ratio #s for each gear, the Longer/ Taller the gears are. obviously it is easier for an engine to pull through 1st gear with its 3.307, then it is to pull through 5th gear with its 0.880.
hth
Old Apr 15, 2003 | 10:47 PM
4inspeed's Avatar
Default Re: s1 compared to ys1???? (sleeper4dr)
ok sorry for the stupidity
so the usdm ys1(ls) woundt be as goos for the b16 as the s1 right, thanks alot for the help guys.
Old Apr 16, 2003 | 10:33 AM
sleeper4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4inspeed &raquo;</TD></TR><TR><TD CLASS="quote">ok sorry for the stupidity
so the usdm ys1(ls) woundt be as goos for the b16 as the s1 right, thanks alot for the help guys.</TD></TR></TABLE>
you are correct. the JDM S1 is a much better trans for an all-motor B16 than the USDM YS1 (LS)
v13tx1301
10
Nov 7, 2007 10:43 PM
JDM DERF
17
Dec 3, 2004 01:16 PM
the g2 teg
Sep 27, 2004 01:10 PM
megotvtec
Apr 3, 2004 07:11 PM
ekvtec831
11
Mar 7, 2004 07:22 PM
