What are the symptoms of bad main relay?
Old Apr 11, 2003 | 08:44 AM
Hondasaurs's Avatar
Default What are the symptoms of bad main relay?
My car no longer has fuel or spark. It just cranks. It ran fine before. Would grounding out the electriacl system on accident blow the main relay?
Old Apr 11, 2003 | 11:23 AM
ill phil's Avatar
Default Re: What are the symptoms of bad main relay? (ZC_CRX)
I don't know if that would blow the relay or not. Some symptoms of a bad relay would be intermittent starts, starts revs up and then loses fuel pressure and won't crank over after that. Then you give it 5-10 min. and it starts up fine. Some of the things that I experienced. You can always pull the relay out and test across the designated circuits with a DMM for continuity.
Old Apr 11, 2003 | 02:25 PM
hatchy's Avatar
http://autorepair.about.com/li...c.htm
Check your ECU fuse as well.
robs accord
Aug 10, 2013 11:55 PM
turbocivic1984
Jun 29, 2008 09:59 AM
Freeltec
14
May 27, 2006 05:46 PM
og asr
Oct 1, 2005 12:14 AM
