not starting when hot....
Old Apr 11, 2003 | 11:33 PM
h2392si's Avatar
Default not starting when hot....
sometimes when i run my car hard(above 5k rpm) or race the lude, the car does not want to start right after, it will start if i just let it chill for a couple of minutes. what do you think it could be?? i replaced the rotor cap, distributor cap, spark plug wires, coil wire, relays- all OEM, battery, and the plugs but those are bosch platinum 4. ive been told that it could be the ignition coil but i dont know. Maybe a fuel problem?? if i drive my car normall and dont f around it starts right up. Any input is much appreciated. Thanks to all in advance.
Old Apr 12, 2003 | 07:03 PM
acuratech's Avatar
Default Re: not starting when hot.... (h2392si)
Next time it acts up turn the key on , but do not crank it over. Watch the check engine light, if you do not hear a faint "click" when the engine light goes off then the main relay is bad..
Old Apr 13, 2003 | 11:28 AM
hatchy's Avatar
Check your main relay and make sure your fuel pump was working. I just replaced mine yesterday, and was having the same problem.
that747guy
34
Jan 2, 2021 09:27 PM
atmdc
Mar 6, 2010 03:10 PM
live_again_integra
Jan 4, 2007 05:42 PM
Dan_UK
Jan 9, 2006 10:36 AM
.ShawnD.
Aug 31, 2002 02:57 PM
