Yet another LS/Vtec question
Old Apr 10, 2003 | 07:58 PM
. o 69 o .'s Avatar
Default Yet another LS/Vtec question
Instead of using a LS bottom end to achieve the longer stroke, could a LS crank and rods be swapped into a b18c bottom end?
This way, no vtec mods have to be done, and you get the extra stroke.
just a though.
Old Apr 10, 2003 | 08:19 PM
warwagon's Avatar
Default Re: Yet another LS/Vtec question (B16B)
works fine know a couple of people who have done it
Old Apr 10, 2003 | 08:21 PM
lazy bum shaughn's Avatar
Default Re: Yet another LS/Vtec question (warwagon)
I would like to hear more imput on this topic. Bump.
Old Apr 10, 2003 | 08:31 PM
jdmcx's Avatar
Default Re: Yet another LS/Vtec question (lazy bum shaughn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazy bum shaughn &raquo;</TD></TR><TR><TD CLASS="quote">I would like to hear more imput on this topic. Bump. </TD></TR></TABLE>
me to
i thaught (don't know if i am right) that the gsr block is not high enough to accomodate the longer rods and crank
i have heard of ls block gsr crank and some unkown rod length don't know though i might be wrong
Old Apr 11, 2003 | 03:27 AM
. o 69 o .'s Avatar
Default Re: Yet another LS/Vtec question (jdmcx)
It is my understanding that the LS and gsr share the same block height, and same bore. however, I think the gsr block needs to have the bottoms of the cylinders machined to have clearance for the LS rods. I believe the cranks are the same size though.
Old Apr 11, 2003 | 08:58 AM
BabyDaddy's Avatar
As long as you use LS length rods with the longer LS crank, you'll be fine. That plus the bottom end width of GSR rods are narrower than LS rods. The journals on the crank are narrower on the GSR crank.
Old Apr 11, 2003 | 10:01 PM
. o 69 o .'s Avatar
Default Re: Yet another LS/Vtec question (BabyDaddy)
How difficult is it to machine the journals to allow clearance for the ls rods? Is this something i can do? or should i take it to a shop?
Old Apr 12, 2003 | 12:36 AM
3rdGteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I would like to hear more input on this topic. Bump. </TD></TR></TABLE>
Old Apr 12, 2003 | 08:46 AM
. o 69 o .'s Avatar
Default Re: Yet another LS/Vtec question (3rdGteg)
B U M P
Old Apr 12, 2003 | 10:21 AM
simple4012's Avatar
New User
the oil squirters get into the way. simply have them moved back a lil bit (away from the rotating mass) and ya good to go. everything else is the same. height and bore
Old Apr 12, 2003 | 11:23 AM
. o 69 o .'s Avatar
Default Re: Yet another LS/Vtec question (simple4012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple4012 &raquo;</TD></TR><TR><TD CLASS="quote">the oil squirters get into the way. simply have them moved back a lil bit (away from the rotating mass) and ya good to go. everything else is the same. height and bore</TD></TR></TABLE>
Is it possible tp just "move em back a bit" ? are they not attched to the block? also... what about rod clearance?
Old Apr 28, 2003 | 06:32 PM
. o 69 o .'s Avatar
BUMp
Old Apr 28, 2003 | 07:46 PM
Chugger's Avatar
i am in the process of building this set up.
it will consist of:
gsr block
balanced ls crank and rods with arp rod bolts
arp head studs
ctr pistons
gsr head
as soon as i know you will know
am waiting on the parts as we speak
i will move the squirters instead of taking them out if i can that is
lata
chris
egboy94
Sep 2, 2009 03:24 PM
victoriasamantha
Dec 27, 2007 05:17 AM
B-B-K
31
Mar 16, 2005 01:30 PM
trucdoken
Mar 12, 2005 09:37 PM
eddiecut
Aug 20, 2002 10:14 AM
