help!!gsr swap into Ek
i have a 98 ek that was automatic now converted to manual. i put in a 99 gsr motor. at first i put in a si engine harness and si ecu ran but no speedo or tach and idled high and no low end. figured out that just doesn't work. so i put in stock ex auto harness with obd2 gsr ecu. now everything is fine BUT it will only rev up to 2 grand and it sounds kinda but it isn't a rev limiter. does not sound healthy at all. i just figured out i forgot the iab senor on the skunk2 mani. could it be bad resistence on a sodered wire,different pin-outs, other forgotten wire. im outta ideas and need help real bad. SOMEONE PLEASE HELP!!!!!!!
Jonzy
Engine Management and Tuning
Sep 17, 2017 10:57 PM
want2drive
Jun 14, 2011 10:11 AM
