differences between b16/b18c1/b18c5 head???
Old Apr 12, 2003 | 11:09 PM
preludacris's Avatar
Modified by preludacris at 12:11 PM 4/15/2003
Old Apr 13, 2003 | 02:32 AM
Default Re: differences between b16/b18c1/b18c5 head??? (preludacris)
Old Apr 13, 2003 | 09:28 AM
Old Apr 13, 2003 | 09:43 AM
SilverJdmhatch's Avatar
what are you doing building an ls/vtec????
Old Apr 13, 2003 | 10:42 AM
Default Re: differences between b16/b18c1/b18c5 head??? (SilverJdmhatch)
Modified by preludacris at 12:12 PM 4/15/2003
Old Apr 13, 2003 | 11:06 AM
bump
Old Apr 13, 2003 | 11:31 AM
justBLZE's Avatar
Chopper 2 Hopper
Ok.
B18c5 is the wildes out of those 3. The B16A2 and B18C5 (Type-R) head are the exact same, PR-3 cast piece. The difference is in cams, valvetrain, mild port and polish on type r head, intake manifold.
Old Apr 13, 2003 | 11:41 AM
Default Re: differences between b16/b18c1/b18c5 head??? (tommySI)
Old Apr 13, 2003 | 12:56 PM
Old Apr 13, 2003 | 01:41 PM
Old Apr 13, 2003 | 02:33 PM
Old Apr 13, 2003 | 03:39 PM
Old Apr 13, 2003 | 04:22 PM
Old Apr 13, 2003 | 05:16 PM
Old Apr 13, 2003 | 06:49 PM
wow
Old Apr 13, 2003 | 08:01 PM
Old Apr 13, 2003 | 10:39 PM
last bump
Old Apr 13, 2003 | 11:59 PM
msilbernagel's Avatar
Ok... I haven't seen much written so I'm going to try from memory.
Mechanically, the B18c1 heads have a different upper bolt pattern where the intake attaches. That's only significant for the choice of intakes. FYI.
Intake runners are slightly larger bore in the R's -- so there is a leaning towards the high RPMs that may loose you a little down (say 4k?).
I saw a flowbench comparison of the b16 .vs. B18c1 and the B16 won out at the high end.. though only slightly. R's come with a mild port around the valves. If you're paying for headwork from a good shop, the 'R' porting advantage is probably neutralized.
Combustion chamber shape -- I think the R's are more pent roof.
The GSR .vs. B16 / Type R have a different cylinder head volume. Check out the table at:
http://raceseek.com/honda_specs.htm
Engine Combustion Chamber Vol (cc)
B18C1 41.6 GSR
B18C5 42.7 97-98 TYPE-R
B18A1 48 90-93 INTEGRA
B18B1 48
B17A1 42.7 92-93 INTEGRA
B16A3 42.7 93-97 DEL-SOL
B16A1-A2 42.7 J.D.M
If you have access to someone who does good work on heads, take your pick. If not, pick either the B16A, b17A, or B18C5 head.
The C5 has a slight advantage out of the box, but if you're doing valves/springs/cams/retainers/porting then they're a push.
Hope that helps.
Mark
Modified by msilbernagel at 9:52 AM 4/14/2003
Old Apr 14, 2003 | 12:25 AM
Default Re: differences between b16/b18c1/b18c5 head??? (msilbernagel)
Old Apr 15, 2003 | 08:11 AM
Old Apr 15, 2003 | 09:28 AM
NonovUrbizniz's Avatar
Loved
forgive me if I'm wrong but Aren't the b16a2 and the b18c5 heads different... I thought there were gains from simply swapping the head from an si to a type r.
I just read somewher on here that they're the same castings but I'm pretty sure that you get gains from the b16 over the c5.
N E one?
Modified by NonovUrbizniz at 7:28 PM 4/16/2003
b18cing_u
Northeast (Sales)
Nov 23, 2006 01:56 AM
Too_Smooth
May 22, 2003 04:49 AM
Too_Smooth
May 22, 2003 04:48 AM
preludacris
Apr 13, 2003 10:40 PM
