What is DTC on the ECU?
Old Apr 12, 2003 | 04:54 AM
flastreetscn's Avatar
Default What is DTC on the ECU?
Can anyone explain to me what does the DTC stand for and what is it's functionality in our ECU?
Thanks,
Old Apr 12, 2003 | 06:41 AM
Chiovnidca's Avatar
Default Re: What is DTC on the ECU? (zeno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeno &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone explain to me what does the DTC stand for and what is it's functionality in our ECU?
Diagnostic Trouble Code. If there is a problem with the system, it will set a code to narrow down the possible problem.
Old Apr 12, 2003 | 08:39 AM
Default Re: What is DTC on the ECU? (TurboD16Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboD16Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Diagnostic Trouble Code. If there is a problem with the system, it will set a code to narrow down the possible problem. </TD></TR></TABLE>
Thanks, although it's still not clear for me. I wonder if I'll ever learn these stuff.
Old Apr 14, 2003 | 07:37 AM
JimBlake's Avatar
When your check engine light (CEL) comes on, your ECU stores a code that says what it thinks is screwed up. Then you short the service connector, & the CEL flashes the code. Or you plug in a code-reader & read the code on its display. Then look up that code in the shop manual for your car.
nolicense526
Jun 27, 2007 07:02 PM
bigislandc2
Aug 31, 2006 09:15 PM
Bseriesy0
Nov 29, 2003 11:46 AM
Waachback
14
Nov 28, 2003 01:36 PM
Prelude Vtec 23
Jul 20, 2003 06:05 AM
