can someone explain wat a purge valve does
Old Apr 12, 2003 | 06:46 AM
roc's Avatar
roc
Default can someone explain wat a purge valve does
i recently converted my b16a2 o obd1.my cx harness has the clips for the purge valve,but it does not plug into the valve on the b16.i called hasport and the told me its not necessary for me to hook it up.is this possible. by the way the purge valve is locates on the fuel rail with vaccum lines to the canister
Old Apr 12, 2003 | 11:44 AM
Chiovnidca's Avatar
Default Re: can someone explain wat a purge valve does (roc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roc &raquo;</TD></TR><TR><TD CLASS="quote">i recently converted my b16a2 o obd1.my cx harness has the clips for the purge valve,but it does not plug into the valve on the b16.i called hasport and the told me its not necessary for me to hook it up.is this possible. by the way the purge valve is locates on the fuel rail with vaccum lines to the canister</TD></TR></TABLE>
Under part throttle operation, it purges the gas fumes in the charcoal canister to be burned in the engine. It's an emmision device. It doesn't hurt performance.
95blackEG
Apr 25, 2006 10:28 PM
mechatune
Apr 7, 2005 07:53 PM
boosted_dc2
Oct 26, 2004 06:02 PM
roc
Apr 8, 2003 01:32 PM
