Welding Tips?
Old Apr 13, 2003 | 06:48 PM
94TealGSR's Avatar
Default Welding Tips?
Well, my brother and I bought a welder today. It's just your standard wire-feed welder, and so far it's been working really well.. we're just looking for some tips and tricks as to how to do this. We had some pretty ugly welds to begin with (I personalyl still do), but they got better as the day went on. Pics below show a good and a bad weld. Anything would be helpful at this point.
Bad Weld (one of the first ones):
Decent Weld (of course the picture would be blurry on the good one):
<FONT COLOR="red">Bonus pictures!!:</FONT>
1: picture of our contraption... lots of odd pieces of pipe welded together, with a downpipe flange on one end and a GS-R crankshaft on the other end!
2: Same contraption, only standing up!
Old Apr 13, 2003 | 06:55 PM
TurboDC4's Avatar
Default Re: Welding Tips? (94TealGSR)
hahaha!!! We need some practice!!
Old Apr 13, 2003 | 06:56 PM
94TealGSR's Avatar
Default Re: Welding Tips? (TurboDC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDC4 &raquo;</TD></TR><TR><TD CLASS="quote">hahaha!!! We need some practice!!</TD></TR></TABLE>
We need water/air tight welds.
Old Apr 13, 2003 | 07:18 PM
Tbone's Avatar
ARHHHH hope that wasnt a good gsr crank. .......
Old Apr 13, 2003 | 07:20 PM
94TealGSR's Avatar
Default Re: Welding Tips? (Tbone)
hahaha hell no, the threads were screwed and a part of the keyway sheered off. Got pics if you really wanna see 'em.
Old Apr 13, 2003 | 08:02 PM
CivicEK.PDX's Avatar
u need a lot of practice....us a method like your drawing a loop with the wire.
Old Apr 13, 2003 | 08:54 PM
RCautoworks's Avatar
Default Re: Welding Tips? (CivicEK.PDX)
Your getting better, but it looks like your going to fast. Take your time, when your welding it, go up and down slowly, almost like zig zags.
Old Apr 13, 2003 | 09:30 PM
Nameless RB26's Avatar
Default Re: Welding Tips? (90blackcrx)
Need some definite work there lololol.
pffaaahahaha.
Old Apr 14, 2003 | 12:22 AM
shorti's Avatar
Default Re: Welding Tips? (Nameless EJ6)
find some flat bar and practice on that
just fart around for a bit till you get the heat and the wire speed to your liking, write you're name, just have fun
then get 2 pieces of flat bar and weld them together at a 90 degree angle
ex. get 2 pieces of 3/8ths flat bar and weld them together with a 2-3i inch weld, once that's done get a hammer and break the ****** apart. make sure you have at least 1/8th inch penitration on both peices of flatbar
that's a good way to figure out how to use your machine
make sure it's not too hot or else you'll melt right through you're pipe (or whatever you're working on) and make sure it's not too cold or else you'll have more welding like in your first pic
hope that helps
Old Apr 14, 2003 | 02:22 AM
SEFIxCivic's Avatar
welding on pipes is pretty hard. u should practice welding on some flat pieces of metal to get the feel of your welder, and then when you go back to welding pipe u'll find its much easier.
Old Apr 14, 2003 | 05:55 AM
CHEETAH's Avatar
Default Re: Welding Tips? (shorti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
just fart around for a bit till you get the heat and the wire speed to your liking</TD></TR></TABLE>
I agree
wire speed is what took me a while to get used to.
greg
Old Apr 14, 2003 | 06:14 AM
1fastVX's Avatar
Default Re: Welding Tips? (CHEETAH)
What model unit are you welding with??..the quality of the welder can make a big difference sometimes!!...there is a Hobart/Miller discussion board that I have learned allot of info off of....and you dont really need to have a Miller/Hobart unit to post there...post the pics of you weld and they will make suggestions on how to improve them...good luck!
http://www.hobartwelders.com/mboard/
Old Apr 14, 2003 | 08:22 AM
94TealGSR's Avatar
We all have some serious tan lines today. Lesson learned.
Old Apr 14, 2003 | 08:27 AM
-RedneckDave-'s Avatar
Working
Whenever i weld i do little circles to make sure i have good penetration and solid beads.
Old Apr 14, 2003 | 10:44 AM
TurboDC4's Avatar
Default Re: Welding Tips? (01accordv6)
I do it and it just all clumps up and i cant get a good bead going
Old Apr 14, 2003 | 10:51 AM
slowdx's Avatar
When i weld i usualy turn it to the lowest feed setting(1 of 4) and go very slowly making almost like moon shapes. Ill show you some of my welds when i get to my brothers house. They best thing to practice on is steel square tubing i usually practice on 1 or 2 inch square tubing and weld it together side by side. Ill show you later on tonight. Just keep practicing. Be careful too.
Old Apr 14, 2003 | 11:40 AM
TurboDC4's Avatar
Default Re: Welding Tips? (slowdx)
I started out on piping, im guessing thats not the best to start on. How do you get a continuous bead going?
Old Apr 14, 2003 | 12:02 PM
1fastVX's Avatar
What model welder?
Old Apr 14, 2003 | 12:13 PM
slowdx's Avatar
Its hard to get a continuous beed going when welding pipe together because there is no "crevasse"(sp) for the weld to go into. Try slowing the feed down and slowing down dont just go in a straight line, like i said do it in liek a moon shape. I am in no way the best welder. Im probably not even that good. But this is what i found to be easiest. lay your left hand down with the palm up and kinda lay the handle of the weldet on it with your right hand gripping itlay the wire where you want to start and hit the button, slowly go from top to bottom in a (((((( kind of motion. I dont know how good of an explanation that was but just practice until it ffeels right.
Old Apr 14, 2003 | 12:57 PM
jji106's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorti &raquo;</TD></TR><TR><TD CLASS="quote">find some flat bar and practice on that
hope that helps
:]</TD></TR></TABLE>
I am a Union auto worker. I weld in the body shop of Mitsubishi Motors in Normal, IL.
I can tell you that The above quote is pretty good advice.
Picture 1:
Wire speed too fast or not enough heat. Turn down the wire speed and/or turn up the heat!!
Picture 2: A little bit better, but I'd say you still aren't getting good penetration.
Old Apr 14, 2003 | 01:03 PM
tpr's Avatar
tpr
Looks like a flux core welder. If possible purchase the "Gas" kit it will make much prettier welds and will make getting the bead started and keep it continious. If you are stuck with the flux core be sure to keep the welding nozzle close to the work. The flux core provides the gas envelope to make the welding possible. Do you welding in a still air place, not in a windy place as the shielding gas will be blown away from the weld location. I would recommedn a class at your local technical college.
Old Apr 14, 2003 | 01:13 PM
civicmatt's Avatar
When you are making a good weld, it should sound like sizzling bacon! Gas shielding will be a little better and easier to use, especially on thinner metals. Just keep practicing! It looks like you guys are having fun learning!
Old Apr 14, 2003 | 11:40 PM
joeseph's Avatar
Go and sign up for a welding class at a local community college. You will usually get hours of hands on instruction, learn how to set up your work, how to get the most out of your machine, and important safety stuff.
Make sure you have the right safety equipment and welding appropriate attire (don't weld in short sleeves). Pick up a hobart guide too. Tubing can be hard to start on, I would recommend you start by running some straight beads along mid steel to get the fell of it then work your way up to more complex things.
Good luck
Justin Olson
Welding / Fabrication
25
Feb 22, 2007 05:29 AM
K20Z1320
10
Nov 18, 2006 08:53 PM
legendboy
17
Sep 24, 2005 12:37 AM
TurboJesse
18
Dec 1, 2004 10:23 AM
Lenthrax
Mar 23, 2003 06:53 AM
