Help with code 23!
Old Apr 11, 2003 | 04:24 PM
CRexcellence's Avatar
New User
Default Help with code 23!
I am spitting code 23 on my p72 in my 89 crx. I have an ls/vtec and of course the ls bottom end doesnt have a knock sensor. Does anyone know how to trick the ecu into thinking that the knock sensor is there? Ideas? please help
Old Apr 11, 2003 | 05:05 PM
wrXtian's Avatar
Default Re: Help with code 23! (jrx2002)
u can chip the ecu, but chips will advance ur timing most of the time and mess with fuel curves..
Old Apr 11, 2003 | 06:13 PM
eg6ajk's Avatar
try using a 1k ohm resistor and grounding the knock sensor wire. otherwise, I offer a chip that can disable just the knock sensor.
Old Apr 25, 2003 | 03:06 PM
New User
Default Re: Help with code 23! (eg6ajk)
Do you guys think if I hooked up a knock sensor to my harness and set it down in the car by the ecu that it would take the code away? I was thinkin that if the ecu sees the power and ground to the knock sensor, then the light would go off? Idea comments?
Old Apr 27, 2003 | 05:53 PM
New User
alright, I tried the 1k ohm resistor and grounded it. The light doesnt come on as fast but it does come back on after 5 mins of driving or so. I am thinking about hooking up a knock sensor
Old Apr 29, 2003 | 09:05 AM
JimBlake's Avatar
What if you got a knock sensor and actually mounted it on the block? As long as you have the sensor, you may as well put it to work.
ek4 sir civic
Jun 28, 2007 07:09 PM
Red_Greddy_Si
Jul 28, 2004 04:45 PM
Fardoche
Jul 31, 2003 10:29 PM
smslude
Jan 14, 2003 10:37 PM
clean99teg
Sep 21, 2002 05:43 PM
