Last stop before the B20 goes in some questions
Old Apr 13, 2003 | 07:50 PM
Blaze45's Avatar
Brrraaaap!
Default Last stop before the B20 goes in some questions
Ok I have everything for the swap but I need to run over some things
Knock sensor
Does the LS ECU require that I have one?
02 Sensor
Can I connect them and just have one downstream b4 the cat?
Axles
I know that you can use 90-93 teg axles by removing the dust seal. Do I a half-shaft or anything of the sort? I want to have all the parts so I don't have to wait around for em.
Vaccum Lines
There is a hole where the 0BD2 Map used to be. I threw the sensor away no thinking that I would need it to seal the hole. What do you suggest that I put over it> On top of the TB there is a large nipple. What is this for? What is the large one on the back of the IM for as well?
Is there anything else suprising when putting in a B20? Like you need MT bolts to bolt up a MT flywheel ect... figured that one out in time. Why didn't Honda just make them all the same length??? lol
tia
Blaze
Old Apr 13, 2003 | 11:30 PM
pissedoffsol's Avatar
25 Year Member
Default Re: Last stop before the B20 goes in some questions (Blaze45)
what car is this going into?
Old Apr 14, 2003 | 04:27 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Last stop before the B20 goes in some questions (delvtecsol)
My bad its going into a 91 Honda CRX non OBD>
Blaze
Old Apr 15, 2003 | 08:51 AM
Blaze45's Avatar
Brrraaaap!
So yeah, no one can help me?
Blaze
Old Apr 15, 2003 | 09:29 AM
94CivicSi's Avatar
I believe the nipple on the TB goes to the evap canister.
Old Apr 15, 2003 | 01:01 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Last stop before the B20 goes in some questions (94CivicSi)
anyone else>????
Blaze
Old Apr 15, 2003 | 05:13 PM
b20guy's Avatar
I believe no, on the knock sensor.. No meaning you don't need one.
One o2 infront of the cat sounds right.
I think the other guy was right about the nipple being for evap.
I'm guessing the other is the brake booster.
dunno on the axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I have everything for the swap but I need to run over some things
Knock sensor
02 Sensor
Axles
Vaccum Lines
There is a hole where the 0BD2 Map used to be. I threw the sensor away no thinking that I would need it to seal the hole. What do you suggest that I put over it&gt; On top of the TB there is a large nipple. What is this for? What is the large one on the back of the IM for as well?
tia
Blaze</TD></TR></TABLE>
Old Apr 16, 2003 | 06:02 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Last stop before the B20 goes in some questions (b20guy)
Thanks anyone else car to add anything??
Blaze
Old Apr 16, 2003 | 10:34 AM
Blaze45's Avatar
Brrraaaap!
no one jeez guess im a bit of a pioneer @ this then
Blaze
JDMDALOUIE
Jul 23, 2011 12:03 AM
onesickhatchback94
Nov 6, 2006 07:16 PM
600_Double_R
May 25, 2006 01:26 PM
ef9one6
Jun 13, 2003 06:39 PM
