Blown CV joint on a 93 Si
Old Apr 14, 2003 | 08:02 AM
Dokta's Avatar
Default Blown CV joint on a 93 Si
I was going to replace my front brake pads on my 93 civic Si. When I took the passenger side wheel off, I saw grease stuck all over my suspension and brake parts. I stuck my finger in my outer outer cv joint and sure enough it was torn the entire way around. Heres the thing, I have a drivers side drive axle with 2 good cv joints. Should I disassemble the cv joint and rebuild the other cv joint on it, or just go buy an axle? Has anyone out there ever done this before?
Old Apr 14, 2003 | 09:50 AM
Aron Parsons's Avatar
Default Re: Blown CV joint on a 93 Si (Dokta)
Save yourself the hassle and buy an axle with a lifetime warranty. This will save your valuable time from having to rebuild your axle. And if in the future this happens again, it won't cost you anything.
Old Apr 14, 2003 | 10:03 AM
Kris's Avatar
Default Re: Blown CV joint on a 93 Si (Aron Parsons)
I build CV Axles and well it's not hard to rebuild the axles seeing that the boot ripped and you were probably driving with it like that it would be smart to get new or cut joints and put them on there or you can simply take it to an axle shop and buy one.
Type 56
Suspension & Brakes
Apr 4, 2017 09:30 PM
hcaulfield57
11
Feb 5, 2017 09:19 PM
Honda cd65
Apr 27, 2013 03:12 AM
B18CivicEH2
Mar 19, 2007 05:13 PM
arren123
Apr 13, 2003 12:54 PM
