Removing AC Condenser Fan Bad?!
Old Apr 13, 2003 | 07:46 AM
Marcos's Avatar
Default Removing AC Condenser Fan Bad?!
Alright, me and my friends have made pretty much all the flanges and pipes we need for installing this turbo on his 95 Civic V-TEC E SOHC, and there is a spacing problem. The AC Condenser Fan is in the way.(NOT RADIATOR FAN) If we were to take the fan and it's shroud off the AC would only get a bit warmer at idle being that there isn't a fan sucking the air through, but if you are moving you have the air while moving to cool it. So, my question is could I remove the AC Condenser fan and run everything successfully, also will it throw the check engine light? Thanks.
Old Apr 13, 2003 | 09:24 AM
Chiovnidca's Avatar
Default Re: Removing AC Condenser Fan Bad?! (Marcos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marcos &raquo;</TD></TR><TR><TD CLASS="quote">Alright, me and my friends have made pretty much all the flanges and pipes we need for installing this turbo on his 95 Civic V-TEC E SOHC, and there is a spacing problem. The AC Condenser Fan is in the way.(NOT RADIATOR FAN) If we were to take the fan and it's shroud off the AC would only get a bit warmer at idle being that there isn't a fan sucking the air through, but if you are moving you have the air while moving to cool it. So, my question is could I remove the AC Condenser fan and run everything successfully, also will it throw the check engine light? Thanks.</TD></TR></TABLE>
Without the fan, when stopped and at low speeds the presure in the a/c system is going to get very high. It won't turn on the CEL.
duyfash0
Oct 8, 2008 06:46 PM
axionm1k
Jun 14, 2008 02:16 PM
playahwitgame
Jun 20, 2006 04:40 PM
95gsr
Jun 27, 2003 02:07 PM
