Question about custom intakes...
Old Apr 11, 2003 | 05:59 PM
RuskeR's Avatar
Default Question about custom intakes...
I have two sections of piping I need to join together. What can I use to combine these pieces together? I have some rubber sleeve that was on an old weapon R intake but, one end is smaller than the other. Any ideas? I went to Home Depot and didn't run across anything. Thanks.
Old Apr 11, 2003 | 06:27 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Question about custom intakes... (RuskeR)
Home Depot has these rubber tubes they are in the installation aisle. They are 2 inches in width and like 4 inches long. I can't remember the exact name. Wait a minute just found my receipt it called a 2" Flexcoupling it cost me $4.21. not sure if it will work depends on the size of the intake tube. Just bring the tubing in side the Depot and see if it will fit before you buy, good luck.
Old Apr 11, 2003 | 07:28 PM
ChiBoy's Avatar
You can get rubber or silcon coolant hose at a truck (semi) parts store. They sell it by the inside diameter so you should be able to get the size you need.
jit01
Sep 5, 2007 07:09 PM
chinaski
May 11, 2005 11:34 AM
martini
Jan 23, 2003 08:36 PM
Chris N
Oct 22, 2002 05:51 PM
Accord15
Apr 18, 2002 06:04 AM
