B17, no spark, no fuel
well i would start with basic checks, like testing the coil. checking your cap, rotor ect...
as far as fuel, listen for your fuel pump to prime the lines, alot of times the fuel pump relays go bad. again im not saying it is any of these things. but these are basic checks you can preform to rule out some factors that could be leading to your problems. also double and triple check the harness for obd 0 to obd 1 and make sure non of the wires fell out.
hope that helps
-sander
hope that helps
-sander
NL826
15
Jan 23, 2010 12:22 PM
a1320honda
Nov 26, 2009 07:46 PM
JolToN49
Nov 20, 2002 11:41 AM
