need help engine won't fire
Old Apr 10, 2003 | 11:03 PM
jspec - integra Ls's Avatar
Default need help engine won't fire
My engine in my acura vigor won't fire, all it's doing is just turning over without firing, I'm not sure what it could be, i know it's a electrical problem, but i just don't know where to start to find the problem. Any feedback would help.
Old Apr 10, 2003 | 11:07 PM
psi420's Avatar
Default Re: need help engine won't fire (jspec - integra Ls)
First check to see if you are getting any spark.
Pull a plug wire, shove screw driver in there, hold the metal stud close to a ground, have someone crank the motor. You should see a nice spark.
If not, you have dist problems.
Pull coil first and check for resistance specs.
You may also have fouled spark plugs, and or wires too.
Check those out first.
JAYDmManny1331
Nov 22, 2009 09:33 PM
909ej195
Oct 9, 2006 08:31 PM
chumpman
May 14, 2005 09:46 PM
90SiHatchbk
May 9, 2004 12:04 PM
blackhatchy
18
Apr 13, 2003 05:27 AM
