curious about sensor placement
Old Apr 11, 2003 | 07:39 PM
MikeSarr_GSR's Avatar
Default curious about sensor placement
Q for those in the know:
Why is the B16a IAT sensor in the intake neck...
and the GSR IAT sensor in the intake manifold????
say I was being inventive and I got me another IAT sensor,
bored a hole in my airbox and installed it in the box. say
I then extended the plugs to the sensor and plugged it
in... and the charge air went from 105... to 85 at stop
to ambient temp while moving?
would it lean or enrichen the setup using the stock ECU
and would there be any power gains on my GSR...
would this require using a VFAC to make better use of this
change?
Old Apr 11, 2003 | 09:28 PM
Default Re: curious about sensor placement (MikeSarr_GSR)
any thoughts?
Old Apr 14, 2003 | 07:24 AM
JimBlake's Avatar
I'm gonna guess it'll try to richen your mixture. But the O2 sensor would read the result, and the ECM will compensate. Have you measured those temperatures or are you guessing what they'll be? I would have guessed the incoming air is moving too fast to pick up much heat from the TB & manifold.
Old Apr 14, 2003 | 11:48 AM
Default Re: curious about sensor placement (JimBlake)
alst time I scanned my car it was reading 105F IAT at idle and 205F coolant temp
at normal operating temp.
ROOSTER.
Jan 31, 2014 05:42 PM
LuckyJDM
Dec 8, 2012 10:28 PM
ACTION JACTION
Engine Management and Tuning
May 17, 2011 03:48 PM
castle1313
Feb 4, 2010 03:56 PM
xasiansupermanx
Nov 5, 2007 08:23 AM
