how to check if a tranny is still good??
Old Apr 11, 2003 | 04:56 PM
pg_thao's Avatar
Default how to check if a tranny is still good??
how do I check to see if a tranny is still good, its off the car.. should i hook up the shift linkage and see if it goes into the gears?
im asking because I had thought that my tranny f*uck up when i couldnt get into 1st gear..so I swap it with a dx tranny.. but when I did that I notice that 1 of the clutch disc spring was loose and one end of spring was out.. will that cause my tranny not to go into 1 gear..??
Old Apr 11, 2003 | 05:18 PM
Nameless RB26's Avatar
Default Re: how to check if a tranny is still good?? (pg_thao)
There's no way to see if it's good. You can see if it's functional though by shifting it around.
Other than that.. you'll have to take it apart and inspect:
synchros/hubs/rings/gears/shafts/bearings/shims/shift forks/shift mechanism etc.
Old Apr 11, 2003 | 09:43 PM
TREVER's Avatar
Default Re: how to check if a tranny is still good?? (Nameless EJ6)
You can bench test it spin the input shaft with one hand while shifting with the other. use a screw driver to shift and make sure you get 6 gears. You can watch the axle splines to see that it rotates when in gear. it won't tell you everything but it helps.
Old Apr 12, 2003 | 12:40 AM
3rdGteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pg_thao &raquo;</TD></TR><TR><TD CLASS="quote">how do I check to see if a tranny is still good, its off the car.. should i hook up the shift linkage and see if it goes into the gears?
im asking because I had thought that my tranny f*uck up when i couldnt get into 1st gear..so I swap it with a dx tranny.. but when I did that I notice that 1 of the clutch disc spring was loose and one end of spring was out .. will that cause my tranny not to go into 1 gear..??</TD></TR></TABLE> I remember Mista Bone or someone saying that this can cause gears not to go in(broken/loose spring on clutch disk).
Old Apr 12, 2003 | 06:14 AM
pg_thao's Avatar
bump
starblades
Transmission & Drivetrain
Sep 8, 2014 05:55 PM
dinthanonh
Oct 12, 2009 02:09 PM
teggy_617
May 14, 2009 05:21 PM
sweesiong78
Jun 1, 2008 10:45 PM
