Hub question 56k watch out
Old Apr 13, 2003 | 10:55 AM
highmilehatch's Avatar
Default Hub question 56k watch out
After breaking off two drill bits in the rotor retaining screws, I was finally able to get this thing off by cutting around it.
However, I cut the slightest bit into the hub. Am I going to encounter any balancing problems with the hub because of these?
I didn't even realize I could be throwing off the balance of the hub possibly. Should I be worried are those small cuts no big deal?
Old Apr 13, 2003 | 05:36 PM
ChiBoy's Avatar
Default Re: Hub question 56k watch out (highmilehatch)
Holy crap did you do it the hard way! The screws are really soft and should have been nowhere nead that difficult to drill out. Did you drill the heads out and use the jack screws, or did you try to drill through the hub?
Old Apr 14, 2003 | 06:23 AM
Default Re: Hub question 56k watch out (ChiBoy)
Well I had a couple drill bits break off in the screws. So it was my only choice. I cut around the screws with a grinder. So its all good now.
Old Apr 15, 2003 | 08:56 AM
tpr's Avatar
tpr
That amount of material so close to the center of rotation should not make any differnece at all.
Old Apr 15, 2003 | 10:10 AM
sander's Avatar
2.7(p/t)
Default Re: Hub question 56k watch out (tpr)
an impact screwdriver is what you need so that doesnt happen again. but congrats on getting it off, thats a serious cut.
laocivic
Suspension & Brakes
Mar 26, 2008 01:52 PM
toguemaster
Suspension & Brakes
May 27, 2006 01:25 PM
bfitz
15
Aug 9, 2005 11:55 PM
lanceh
Mar 31, 2003 07:44 AM
lordhuh
Jul 6, 2002 06:58 PM
