toda b cams queston
Old Apr 13, 2003 | 09:49 AM
iblewmyrmotor's Avatar
Default toda b cams queston
will b's fit in a gsr block with ctr's, si head.. the head has been milled a few times for clean fresh surfacing..so if anone had any info i'd greatly appreciate it.. thanx
Old Apr 13, 2003 | 10:25 AM
Chugger's Avatar
Default Re: toda b cams queston (iblewmyrmotor)
what do you mean milled a few times? to just keep it level or has it been shaved to raise compression? you shouldnt have any problems with the ctr's because the si had loses compression cause of the combustion chamber but since its been shaved you should find out how much just so you know. but b's arent that aggressive so you shouldnt have a problem i believe sgt was runnin c's with ctr's andhe had no issues what so ever
Old Apr 14, 2003 | 06:03 AM
Default Re: toda b cams queston (Chugger)
chugger thanx for the reply.. also im using a mugen head gasket and the head wasnt milled to raise compression it was just to clean it up.. let me know what you think about the head gasket also.. thanx.
Old Apr 14, 2003 | 07:48 AM
qtiger's Avatar
I would highly suggest that you clearance your motor. Milled with a thin headgasket and CTR pistons? Asking for trouble.
MEANB18
Aug 3, 2003 03:21 PM
Beave0101
Jan 1, 2003 06:35 PM
TypeR0149
Feb 24, 2002 07:12 AM
WayneGro
Nov 30, 2001 06:31 PM
Mr. Softee
Aug 21, 2001 12:55 PM
