VAFC Help...
Old Apr 12, 2003 | 04:36 PM
Turbo Powa's Avatar
Default VAFC Help...
I set it up just like the manual says. For some reason when I step on the gas all the way with the car off, it reads 9 on the throttle. Is this normal? Shouldn't it be going all the way to 10 for WOT? What do I need to do the fix this? DO i need to reinitialize and do the 10 sec no thorttle/10 WOT?
Old Apr 12, 2003 | 05:14 PM
sslude's Avatar
Default Re: VAFC Help... (Panda EK)
i dont what you would do, check all the wiring again. yes, it should say 10
Old Apr 12, 2003 | 05:18 PM
Turbo Powa's Avatar
Default Re: VAFC Help... (sslude)
checked them all.... everything is fine. Maybe the throttle cable is not in the right spot? I dunno, I saw the vafc when I open the throttle from the engine bay it will go up to 10 but when I get in the car and step on it, it goes to 9
Old Apr 12, 2003 | 05:54 PM
Turbo Powa's Avatar
anyone?
Old Apr 12, 2003 | 06:46 PM
Turbo Powa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panda EK &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
Old Apr 12, 2003 | 07:37 PM
VTEC-DA's Avatar
My friends says 0 at WOT and 10 at no throttle, so consider yourseld lucky, you are at least closing to being right than he is.
Old Apr 12, 2003 | 08:08 PM
boostsohfast's Avatar
Default Re: VAFC Help... (VTEC-DA)
If it goes to 10 when you open the throttle body from the engine bay but not when you step on the gas try tightening up the throttle cable some.
Old Apr 12, 2003 | 08:30 PM
Turbo Powa's Avatar
Default Re: VAFC Help... (boostsohfast)
I did but them it goes to only 8 when I step on the gas all the way down.
Old Apr 12, 2003 | 08:40 PM
did you have anyone press the pedal while you were looking under the hood to see if the throttle body opened to the same position as when you open it with your hand? If it does, then I guess it must be something electrical.
Old Apr 13, 2003 | 09:54 AM
Turbo Powa's Avatar
No I havent checked that out yet. I think its just the cable since I did a mini me swap. I tried adjusting the cable but it gets worse. Maybe its just the way the cable is set up. I may need to set it up differently?
Old Apr 13, 2003 | 01:58 PM
Turbo Powa's Avatar
Weird.. drove today and while the car is on it will hit 10 at wot but with the car off it will only go to 9
HondaH22a#1
Aug 16, 2007 06:50 AM
smkngsr
11
Oct 11, 2005 05:42 PM
smkngsr
May 19, 2005 09:15 PM
Art Vandeleigh
Oct 26, 2002 09:14 PM
buzzman
Apr 12, 2002 09:51 AM
