Oil around spark plug threads....is this a problem?
Old Apr 14, 2003 | 05:39 AM
Witty's Avatar
Default Oil around spark plug threads....is this a problem?
I changed my spark plugs this weekend and noticed that there was oil around the threads on one of them. Just wanted to know if this is a potential problem?
Old Apr 14, 2003 | 06:11 AM
Hriday's Avatar
Default Re: Oil around spark plug threads....is this a problem? (Witty)
It's not a huge problem but it means you'll need new seals, which also means you'll probably need a new valve cover gasket (unless your's is new), because thats the only way to change the seals. They're just little round rubber pieces that fit in between the head and the valve cover. They're really cheap and it's an easy job. Best of luck to you.
Old Apr 14, 2003 | 06:23 AM
Witty's Avatar
Default Re: Oil around spark plug threads....is this a problem? (Hriday)
Cool, I think I can figure out how to do that. Thanks for the reply.
Old Apr 14, 2003 | 10:28 AM
TRENDSETTLER's Avatar
yeah just replace those seals....its really easy and cheap
relentlesstech
12
Feb 3, 2014 07:56 PM
Zendos
Nov 4, 2009 04:04 PM
foxfai
Mar 31, 2009 08:03 AM
Dj Skidz7
Aug 22, 2008 09:08 PM
jok
Aug 1, 2004 10:43 AM
