Checking Engine Compression
Old Apr 11, 2003 | 07:28 AM
7rrivera7's Avatar
Default Checking Engine Compression
Ok, so I just bought an engine compression tester and the sales person told me I have to convert from kPa to psi. Does anyone have a formula to do this?
Do most of you just read the number on the gauge (so the conversion from kPa to psi is unnecessary) to make sure the values are consistent from one cylinder to the other or should I be looking for a 'magic' compression value for the 1st gen B16a?
If I'm running JE SRP 10.5:1 pistons, where should my compression be sitting more or less?
Thanks!
Old Apr 11, 2003 | 09:20 AM
7rrivera7's Avatar
Default Re: Checking Engine Compression (7rrivera7)
ttt
Old Apr 11, 2003 | 11:33 AM
psi420's Avatar
http://www.worldwidemetric.com/metcal.htm
Bar - psi
Your compression numbers should be around 200+
You want consistency between all 4 cylinders.
Differences up to about 15-20 are normal.
Old Apr 11, 2003 | 03:22 PM
JimBlake's Avatar
One psi = 6.895 kPa
So 1,200 kPa would be 174psi
michaelcal12
Honda Civic (2001 - 2005)
Dec 13, 2012 07:49 AM
duf2570
Oct 18, 2012 01:20 AM
range hadies
Mar 25, 2012 12:18 PM
ace8
Dec 1, 2009 04:16 PM
EG6 Love
Feb 15, 2008 05:06 PM
