Ok, WTF is wrong?
Old Apr 11, 2003 | 04:41 PM
IllusionOfSafety's Avatar
Default Ok, WTF is wrong?
Maybe im just a dumbass or maybe im missing something, I dont know.
Heres the problem:
Today i was going to install new brake rotors/pads, so i loosen the bolts, jack up the car, and take off lug nuts and, THE F'N WHEEL DONT COME OFF.
what the hells up with that, never happened before?
Anyway to get the bitch off?
Old Apr 11, 2003 | 04:51 PM
RCautoworks's Avatar
Default Re: Ok, WTF is wrong? (IllusionOfSafety)
Happen to me once, solution, give the wheel a good kick. It will pop right off.
Old Apr 11, 2003 | 04:57 PM
msilbernagel's Avatar
Front, rear, disk, or drum?
With drum brakes, the ridge can cause it to stick. You may have to back off the adjustment so that the drum slides off the shoes. .. or, as he says, "give it a kick".
Rotors... you did lift the calipers, didn't you?
Good luck!
Old Apr 11, 2003 | 06:34 PM
DK4200's Avatar
Default Re: Ok, WTF is wrong? (msilbernagel)
Just give it a good kick like the guy above said... the rim basically freezes on, then you'll be good to go
Old Apr 11, 2003 | 07:32 PM
VTECorona's Avatar
Default Re: Ok, WTF is wrong? (DK4200)
Mine do that too, you just gotta tug at it. Tug at different spots on the perimeter of the wheel and itll eventually come loose.
Old Apr 11, 2003 | 07:47 PM
Ideal R's Avatar
New User
Default Re: Ok, WTF is wrong? (97RedTegGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RedTegGSR &raquo;</TD></TR><TR><TD CLASS="quote">Mine do that too, you just gotta tug at it. Tug at different spots on the perimeter of the wheel and itll eventually come loose.</TD></TR></TABLE>
That's what I did last time and it works
Old Apr 14, 2003 | 07:18 AM
JimBlake's Avatar
Default Re: Ok, WTF is wrong? (Ideal R)
Then put some grease or anti-seize on the round center part of the hub, where it was seized into the center hole of your wheel. You'll thank yourself next time...
torkair
Feb 21, 2009 01:40 AM
basmasta7
Sep 10, 2008 07:38 AM
JRizEJ6
11
Jul 11, 2008 07:25 PM
IntegraBoy04
Feb 4, 2004 07:18 PM
Halo
Mar 16, 2002 02:07 PM
