Why isn't my right headlight lighting up?
Old Apr 12, 2003 | 10:06 AM
slvrcivic97's Avatar
Default Why isn't my right headlight lighting up?
Well, last night, my right headlight bulb went out on me on my way home. This morning, I took a look at it and I found out that the Left headlight works, and the right headlight doesn't. I put the good bulb from the left headlight into the right headlight and what do you know, it didn't work So, my question is, I checked the power from the right headlight and there is no juice. Where could the problem of this be coming from. I checked the connector that touches the bulb, and cleaned it up but still doesn't work. Any help would be greatly appreciated. I know it may sound like a simple problem and I hope it is, I would just really like to know where the problem is. I called Honda and they wouldn't be able to get my car in for another week So I am still trying to figure it out today so I can see at night tonight. Thanks again.
Old Apr 12, 2003 | 11:12 AM
poison's Avatar
Most likely cause -- blown fuse.
Check your under dash fuse panel for any blown fuses.
Old Apr 12, 2003 | 11:23 AM
Chiovnidca's Avatar
Default Re: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Most likely cause -- blown fuse.
Check your under dash fuse panel for any blown fuses.</TD></TR></TABLE>
Headlight fuses are usually in the under hood fuse box.
Thank you! I totally forgot about the fuse box inside. I was checking the fusebox under the engine compartment. Stupid me Thanks again!
otsegolectric
Jul 22, 2008 10:47 AM
Will_H
Sep 8, 2007 05:19 AM
Senbonzakura
Jan 4, 2005 07:48 PM
Accorddrver
Apr 27, 2004 09:41 AM
Turbo RSX-S
Apr 19, 2004 10:51 PM
