L3 transmission problem
Old Apr 14, 2003 | 12:21 PM
WONG FRIED RICE's Avatar
Default L3 transmission problem
i took apart my tranny to change some bearings and seals...and when i put it back together i found that the shift selector was not aligned correctly with the bottom of the shift forks. The selector, when in neutral, is supposed to be aligned with 3rd and 4th gear shift fork correct? On mine...the shift selector is all the way to 1st and second gear shift fork...i don't think that is right.... what happend??? How do i find/fix the problem??
Old Apr 15, 2003 | 09:23 AM
Default Re: L3 transmission problem (JDMB16ACRX)
ttt
Old Apr 16, 2003 | 10:52 AM
nobody has any idea?
Old Apr 16, 2003 | 03:02 PM
PupaScoopa's Avatar
Move the shift forks/slector ring up/down the shaft until all three points at the shift piece are aligned. Then, study how the shift mechanism moves the shift piece (the rod that comes out of the transmission turns and moves in/out).
There are three different parts to align before it'll go together easily. The easiest is the shift selector (rod??) first then the shifter forks.
Old Apr 17, 2003 | 09:05 AM
Default Re: L3 transmission problem (PupaScoopa)
thanks for the tip...i was looking last night... and i noticed the spring and hat at the end of the shift selector rod looked odd... so i turned it around and put it back in. Looked like i fixed the problem hehehe such simplicity can create such headaches
stevenDAtegra
Transmission & Drivetrain
12
May 3, 2010 10:57 PM
92hatchboi
Oct 22, 2007 06:13 PM
91(si)hatchey
Sep 6, 2006 08:57 AM
BorderM3
Mar 18, 2003 09:25 AM
