Need help with Evap purge valve
Old Apr 10, 2003 | 08:28 PM
The Jamaican's Avatar
Default Need help with Evap purge valve
Here's my problem, it's a 97 civic hx with a jdm obdII b16 being installed and the motor didn't come with the purge valve or any where to put one and I can't seem to locate a valve on the old motor. What would happen if I were to not plug it up and do away with the evap system? I'm also using a usdm 98 gsr ecu.
Old Apr 11, 2003 | 05:58 AM
anybody
Old Apr 11, 2003 | 06:05 AM
liquid51's Avatar
Default Re: (The Jamaican)
well, from what I know, you'll just build up pressure in the fuel tank and release it into the air every time you open your gas cap. It's an environmental issue. I think there pretty easy to make work though, if you can get a hold of the valve.
Use your best judgement.
You don't see a plug on top of the intake runners behind the fuel rail?
Old Apr 11, 2003 | 08:16 AM
there is the connector on the wiring harness but nothing on the intake runners or fuel rail to plug into.
jrlink2k
Honda S2000
Feb 14, 2020 03:05 PM
dishjuarez
Jan 31, 2012 05:46 PM
83gs1100g
Nov 19, 2010 10:47 AM
ch00dlz
Aug 3, 2006 05:36 PM
roc
Apr 12, 2003 11:44 AM
