cant separate front upper control arm from knuckle
Old Apr 14, 2003 | 10:42 AM
auto-x's Avatar
New User
Default cant separate front upper control arm from knuckle
is there a special to separate the front upper control arm from the knuckle? are there any technique to do that? i need your help guys. thanks.
Old Apr 14, 2003 | 10:51 AM
hybridb18's Avatar
Default Re: cant separate front upper control arm from knuckle (gude boi)
either go get a ball joint splitter, (it looks like a tuning fork), or take a hammer and hit the spindle by the ball joint. DO NOT HIT THE UPPER BALL JOINT BOLT!!!.
Old Apr 14, 2003 | 08:11 PM
EKFerioHawaii's Avatar
Default Re: cant separate front upper control arm from knuckle (hybridb18)
Um...I'm a bit cautious when it comes to this. I basically dismantled the whole suspesion assembly and had it pressed out at my uncles shop.
Old Apr 14, 2003 | 11:00 PM
blah13's Avatar
Default Re: cant separate front upper control arm from knuckle (EKFerioHawaii)
Go buy a pitman arm puller, $10, the 2 arms fit over the little tabs and then you tighten the bolt on the underside of the ball joint bolt and it pops right out. Getting it pressed at a shop is a joke. Very easy.
Old Apr 15, 2003 | 12:46 AM
auto-x's Avatar
New User
Default Re: cant separate front upper control arm from knuckle (blah13)
thanks guys, actually i tried that arm puller from pep boys and it cost me 26 bucks and didnt work. i cant keep the arm and bolt stay in one place(keep sliding the fuka). i also tried the fork separator and a hammer doing it all sunday morning. it looks like the bolt connecting the knuckle seized inside, im spraying pb blaster every morning and will try again this weekend. for all.
LutherX
Aug 21, 2011 07:59 AM
kyden
Suspension & Brakes
Jan 25, 2006 10:56 PM
EX-JAY
Oct 25, 2004 02:46 PM
speed_racer012
32
Mar 12, 2004 02:58 PM
IggDawg
Nov 20, 2003 06:25 PM
