using a brake parts cleaner
Old Apr 11, 2003 | 03:44 PM
rody084's Avatar
Default using a brake parts cleaner
hi,
my brakes are making a horrible noise (not the screeching from the warning indicator thingy)... i have a can of brakleen cleaner... and it says to spray it all over the brakes except the rubber parts. am i spraying on the brake pads and the rotors?
this is what i interpret from the instructions, but I want to make sure that im not going to mess things up by spraying it on the pads or the rotor.
if i take out my pads, is it safe to clean the contact area with this product and then put them back in? or should i even bother doing that?
Old Apr 11, 2003 | 03:47 PM
VTECorona's Avatar
Default Re: using a brake parts cleaner (rody084)
spray the rotor and the contact surface of the pads. you may have to take apart the caliper to get to the inner pad
Old Apr 11, 2003 | 03:55 PM
rody084's Avatar
Default Re: using a brake parts cleaner (97RedTegGSR)
ok, thanx wasnt sure if i was supposed to spray the contact area or not.
now another question... i got some brake lubricant, but i am not sure what parts i am supposed to apply it to
Modified by rody084 at 1:53 AM 4/12/2003
Old Apr 14, 2003 | 07:14 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rody084 &raquo;</TD></TR><TR><TD CLASS="quote">... i got some brake lubricant, but i am not sure what parts i am supposed to apply it to..</TD></TR></TABLE>
That would probably be grease for the caliper slide pins & the places where the pad backing plates rub against the caliper.
emperor559
Feb 11, 2008 05:36 PM
compo1
May 2, 2007 12:15 PM
RiCE On IcE 2
Apr 21, 2005 09:41 AM
yaya
May 19, 2003 08:18 PM
216.226.142.95:27016
Apr 9, 2003 07:55 PM
