turbo integra
Old Sep 22, 2019 | 09:23 PM
apocalypse EPT's Avatar
Default turbo integra
plz help me, i am running a b20v on 13lbs of boost and want to lower the boost alittle, if i lower the wastage spring would i need to re tune the car? the spring i have is a 13lb spring, but if i put a 8lb spring would i need to retune it?
Old Sep 25, 2019 | 09:25 AM
Chance EG's Avatar
Default Re: turbo integra
You should be able to lower the PSI on a turbo car without needing a retune, you just shouldn't RAISE the boost without at the very least doing some street tuning/data logging.
If you make 13PSI of boost at redline then obviously you're making 0-12PSI of boost through the rest of the RPM band. The car should already know how to behave at 8PSI.
Old Sep 25, 2019 | 09:34 AM
2x0's Avatar
2x0
10 Year Member
Depends on how good the tune is. If it was only tuned along the curve you get with the 13psi spring and at WOT, then parts of the fuel map may need adjusted when running lower boost pressures at WOT. The ideal way to do it is run a small 7-8psi spring and tune it on wastegate only, then add a boost controller to increase to the desired boost level, tuning at small increments as you turn it up. This way the fuel map will be complete.
apocalypse EPT
Sep 22, 2019 09:24 PM
ctownintegra
Jul 9, 2008 02:41 AM
9deuce9rr
Mar 28, 2004 12:32 PM
RoachForLife
Feb 6, 2004 11:50 AM
Turbo_Teg
Jan 14, 2002 07:35 PM
