Vertical Intercooler and piping for 700whp
Old Aug 17, 2020 | 05:54 PM
lriver0001's Avatar
Icon6 Vertical Intercooler and piping for 700whp
I will be shooting for 700+ whp in my EP3 and I am having difficulty choosing an intercooler.
Also, is 3" piping necessary at that power level?
I only ask that because there are a few intercoolers that have 2.5" inlet and outlet but are rated for 800 horsepower.
https://www.speedfactoryracing.net/s...ow-intercooler
Core size is 27"x6"x3"
Rated for 800hp
https://www.treadstoneperformance.co...1000hp/p104567
  • Core Size 25.00" X 6.00" X 3.50"
  • 3.00" Inlet/Outlet
  • Rated for 1000hp
Would the treadstone be too much for me or is this a good choice?
https://sheepeyrace.com/products/she...ow-intercooler
same specs as the Speedfactory intercooler
These are my top 3 choices right now with the treadstone slightly in the lead.
Thanks in advance!
Old Aug 18, 2020 | 02:15 AM
extremeracer's Avatar
Default Re: Vertical Intercooler and piping for 700whp
Also have a look at KLM, they have some nice intercoolers too. I believe in 3" piping at your target power level. The Treadstone cores are allegedly not as efficient as some of the others but are well priced.
A good high-efficiency 3" core will keep things nice and simple.
https://klmfab.com/product/vertical-...r-800-1000-hp/
Old Aug 18, 2020 | 03:47 AM
lriver0001's Avatar
Thanks man! Always helping out.
If 3" piping is what I should use why are some of the intercoolers using 2.5" inlets and outlets? Wouldn't that be a bottleneck in the system if I'm using 3" piping?
Old Aug 18, 2020 | 04:31 AM
lriver0001's Avatar
I'm liking the KLM now. I don't see any core specs but they use vibrant cores, so that's good.
Old Aug 18, 2020 | 07:35 PM
TheShodan's Avatar
Moderator
Not really. At 700whp or so you're still under Mach 3 in air speed, more than enough for 2.5 pulling and 700whp.
Old Aug 19, 2020 | 06:30 PM
lriver0001's Avatar
In saying this, is 2.5" piping sufficient or should I still go with 3" but not worry if the intercooler has 2.5" inlet and outlet?
Old Aug 20, 2020 | 02:20 PM
TheShodan's Avatar
Moderator
2.5" is fine for your needs. 3" makes fitment VERY complicated more than necessary on some chassis.
Old Aug 21, 2020 | 12:22 AM
Balor_Gr's Avatar
Have you done your homework on vertical vs horizonal intercoolers?
Old Aug 21, 2020 | 05:25 AM
lriver0001's Avatar
Thanks man!
Old Aug 21, 2020 | 05:27 AM
lriver0001's Avatar
I honestly haven't. For my chassis (EP3) I need a same side inlet and outlet intercooler so my choices are limited. Most intercoolers this style and vertical.
d16z6_civic
Jul 5, 2007 03:52 PM
B18 CYA
Apr 14, 2004 06:08 AM
B20LS-T
May 9, 2002 11:06 PM
