Turbo Coolant Return Question.
Old Feb 11, 2020 | 02:08 PM
ILOVEYOURHONDA's Avatar
Default Turbo Coolant Return Question.
Was curious where you guys are returning the coolant from your ball bearing turbos? As of now mine is in the head which i believe is causing my temp sensor to read super high? Anyone else have this issue? I have ordered the freeze block -6 fitting from full race to move the return from the block.
Old Feb 11, 2020 | 02:55 PM
2kdrift's Avatar
Default Re: Turbo Coolant Return Question.
There's really nota return side just needs water running thru it but usually radiator to coolant drain plug on block or if that doesent work/ not available bung can be welded to t start housing
Old Feb 11, 2020 | 03:31 PM
gotcha sir. I’m having an issue with the temp reaching 200-210 i was thinking many because the coolant return is directly right next to the temp sensor.
Old Feb 12, 2020 | 03:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
On my setup one side goes to the bottom of the radiator and the other side goes to the water pipe under the intake manifold.
What fan are you using, do you have a shroud, and what are the fan settings in your tune? I recommend a puller SPAL fan with a shroud and setting the tune to run the fan over 185F up to 90 mph vehicle speed. I made these changes and went from a cruising temperature of 205F down to 185F. Even in the summer with running AC the highest I saw was about 192F.
Old Feb 12, 2020 | 04:50 AM
TheShodan's Avatar
Moderator
Agreed. You won't see any changes with your coolant line rerouted. the coolant in the turbo doesn't get hot enough to csuse sensor issues.
Old Feb 12, 2020 | 12:08 PM
Txdragon's Avatar
Old Feb 16, 2020 | 11:46 PM
Im using a SPAL pusher fan because there’s now space for a puller with running a 4” downpipe. I re routed the coolant return to the block also wrapped the down pipe (kinda shitty) but seems to have done the trick with the temp staying around 190-195 sitting. This is also without my bumper on which I’m hoping to not have to cut my JDM front bumper 🤦🏻‍♂️.
jeremyrocksursox
Oct 31, 2009 03:12 PM
kccord
May 26, 2009 06:08 AM
95BoostedEJ1
Feb 22, 2009 08:15 AM
Cyber ITR
Apr 3, 2007 06:48 AM
Low ofset turtle
Nov 15, 2006 11:26 AM
