Troubleshooting: Not enough voltage to injectors causing intermittent startup
Old May 21, 2020 | 07:30 AM
1320vickers's Avatar
Default Troubleshooting: Not enough voltage to injectors causing intermittent startup
I have 1200 cc injectors running s300 and it was running fine until I started it one day it barley wants to hit now I hooked a led light to BBC heck pulse it seems normal. I used a battery and ran wires straight to the injectors the all clicked and sprayed the fuel pump is on a toggle and the fuel pressure gauge is around 40
Old May 21, 2020 | 11:41 AM
civic-steve-94's Avatar
Default re: Troubleshooting: Not enough voltage to injectors causing intermittent startup
Was your fuel pressure taken before of after the fuel filter.
Old May 22, 2020 | 07:42 AM
TheShodan's Avatar
Moderator
Default Re: Troubleshooting: Not enough voltage to injectors causing intermittent startup
What style injector? Bosch? Rochester/Lucus? what connectors? Sounds like an injector driver issue at first (actually 5th) read of this question.
1320vickers
Jul 14, 2019 10:59 PM
Boostedjay
Jan 31, 2010 01:32 PM
russianswty
27
Nov 14, 2006 06:30 PM
infulleffect
May 4, 2006 06:19 PM
