Recommended spark plugs for high comp CRVTEC?
Old Jun 26, 2002 | 11:55 AM
badCRX's Avatar
New User
Default Recommended spark plugs for high comp CRVTEC?
I picked up a set of plugs from Acura for the GSR/Type R and will start off the break in period with those, barring any problems. Anyone here have suggestions?
Old Jun 26, 2002 | 12:12 PM
Nate B's Avatar
Default Re: Recommended spark plugs for high comp CRVTEC? (badCRX)
NGK Copper
Old Jun 26, 2002 | 04:56 PM
builthatch's Avatar
MiG-21 superfan
NGK bcpr6e-11 or bkr6e-11 depending how high c/r? if its high like 13:1 and you live in cali i'd run bkr7e-11 but im looking and you doint live in cali so try the 6's
[Modified by builthatch, 8:57 PM 6/26/2002]
Old Jun 27, 2002 | 06:56 AM
badCRX's Avatar
New User
Default Re: Recommended spark plugs for high comp CRVTEC? (builthatch)
I remember the ones I got have the 6 on it. I do have access to 92 octane out here running approximately 12.5:1, but maybe a tad higher.
Old Jun 27, 2002 | 07:59 AM
sgT's Avatar
sgT
Default Re: Recommended spark plugs for high comp CRVTEC? (KILLERB18)
NGK Copper
Plantinum work better.
NGK PFR7G11 or BKR7EVX11
Old Jun 27, 2002 | 12:24 PM
Nate B's Avatar
Default Re: Recommended spark plugs for high comp CRVTEC? (sgT)
yes platinums are a little bit better but not worth the difference in cost. I'm putting down the same HP on the dyno with coppers as I was with platinums, they've lasted me about a year now and still spark great. nothing against platinums though, if you want to pay for them its your choice.
Old Jun 27, 2002 | 07:04 PM
TodaSi's Avatar
The BKR7EVX11 are not that expensive, $5 each
Old Jun 27, 2002 | 10:07 PM
rocket_R's Avatar
Default Re: Recommended spark plugs for high comp CRVTEC? (TodaSi)
whats the part number for the ngk copper? do i want to get hotter or colder plugs for n/a set up?
Old Jun 28, 2002 | 01:34 AM
kinesistech's Avatar
Default Re: Recommended spark plugs for high comp CRVTEC? (rocket_R)
If you plan on staying N/A, the just keep the stock platinum plugs that you already have. Platinum is only bad for fordced iduction, because its higher operating temp. can induce detonation. If your N/A stock is fine. Why does everyone think Honda didnt want the best for their engines?
Old Jun 28, 2002 | 09:21 AM
builthatch's Avatar
MiG-21 superfan
colder when an engine is detonation prone and operates at high engine speeds.
Old Jul 1, 2002 | 10:03 AM
builthatch's Avatar
MiG-21 superfan
platinum does not conduct better than copper, BUT, most coppers are copper core and nickel outside, which is on par with platinum conductiviti...the advantage to platinum is its durability and longevity, hence hondas use of em in high rpm production engines. silver is the best conductor and evidently iridium is on par with silver but last alot longer.
OneCrzySetup
Nov 17, 2006 11:53 AM
John.
Jan 11, 2006 03:33 AM
Markov
Oct 7, 2005 10:33 AM
LSVTEC 91 Civic
May 16, 2004 04:24 PM
civileng25
Jun 28, 2003 02:38 PM
